Einleitung
This guide will show you how to access and replace the Sony Ericsson s710a battery and main keypad. Use this guide if the battery needs to be replaced or the keypad needs to be cleaned or repaired. You can also remove the keypad, decorate it, and have your phone stand apart from the crowd.
Was du brauchst
Using the iFixit opening tool, pry off the plastic piece at the bottom of the keypad.
Remove two 6 mm screws from beneath the previously removed plastic cover using a Phillips #00 screwdriver.
Completely remove the back plastic cover.
After removing the board, you will see the plastic keyboard beneath. This can be removed by hand and is very flexible.
You have successfully removed the keypad. You can clean, decorate, or replace the keyboard without worrying about damaging the phone.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
