Zum Hauptinhalt wechseln
Sony Ericsson xPeria Active Camera Replacement
Was du brauchst
  1. Sony Ericsson xPeria Active Camera Replacement, Remove the back cover.: Schritt 1, Bild 1 von 3 Sony Ericsson xPeria Active Camera Replacement, Remove the back cover.: Schritt 1, Bild 2 von 3 Sony Ericsson xPeria Active Camera Replacement, Remove the back cover.: Schritt 1, Bild 3 von 3
    • Open the flaps and remove the back cover using the plastic opening device.
  2. Sony Ericsson xPeria Active Camera Replacement, Remove inside plastic battery cover.: Schritt 2, Bild 1 von 2 Sony Ericsson xPeria Active Camera Replacement, Remove inside plastic battery cover.: Schritt 2, Bild 2 von 2
    • Remove the battery shield with the plastic opening device.
  3. Sony Ericsson xPeria Active Camera Replacement, Remove the battery: Schritt 3, Bild 1 von 2 Sony Ericsson xPeria Active Camera Replacement, Remove the battery: Schritt 3, Bild 2 von 2
    • Remove the battery.
  4. Sony Ericsson xPeria Active Camera Replacement, Unfastening The Motherboard Cover: Schritt 4, Bild 1 von 1
    • Unscrew the 5mm screws with the T5 head.
    • Unscrew the 6mm screw with the T6 head.
  5. Sony Ericsson xPeria Active Camera Replacement, Removing The Motherboard Cover: Schritt 5, Bild 1 von 2 Sony Ericsson xPeria Active Camera Replacement, Removing The Motherboard Cover: Schritt 5, Bild 2 von 2
    • Remove the black cover with the plastic opening tool.
    • Remove the headphone jack from its slot.
  6. Sony Ericsson xPeria Active Camera Replacement, Unplug the back motherboard plug.: Schritt 6, Bild 1 von 2 Sony Ericsson xPeria Active Camera Replacement, Unplug the back motherboard plug.: Schritt 6, Bild 2 von 2
    • Unplug the plug from the motherboard.
  7. Sony Ericsson xPeria Active Camera Replacement, Remove motherboard from device case.: Schritt 7, Bild 1 von 1
    • Using the plastic opening tool, carefully pry up on the edges of the motherboard, opposite of the jacks.
  8. Sony Ericsson xPeria Active Camera Replacement, Remove the display ribbon cable: Schritt 8, Bild 1 von 2 Sony Ericsson xPeria Active Camera Replacement, Remove the display ribbon cable: Schritt 8, Bild 2 von 2
    • Carefully pry up on the tab holding down the display ribbon cable and remove the ribbon cable.
  9. Sony Ericsson xPeria Active Camera Replacement: Schritt 9, Bild 1 von 2 Sony Ericsson xPeria Active Camera Replacement: Schritt 9, Bild 2 von 2
    • Use the plastic opening tool to pry the ribbon cable away from the motherboard.
  10. Sony Ericsson xPeria Active Camera Replacement, Remove camera from device: Schritt 10, Bild 1 von 2 Sony Ericsson xPeria Active Camera Replacement, Remove camera from device: Schritt 10, Bild 2 von 2
    • Pull the camera out through the front of the motherboard.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team 14-5, Leahy Fall 2014 Mitglied von USF Tampa, Team 14-5, Leahy Fall 2014
USFT-LEAHY-F14S14G5
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 14
Insgesamt: 996
