Einleitung
Sometimes, the screen can become cracked, damaged, or just simply not work. This can be frustrating, but never fear, as this replacement guide will make everything easier.
  1. Open the flaps and remove the back cover using the plastic opening device. Open the flaps and remove the back cover using the plastic opening device. Open the flaps and remove the back cover using the plastic opening device.
    • Open the flaps and remove the back cover using the plastic opening device.
  2. Remove the battery shield with the plastic opening device. Remove the battery shield with the plastic opening device.
    • Remove the battery shield with the plastic opening device.
  3. Remove the battery. Remove the battery.
    • Remove the battery.
  4. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Unscrew the 5mm screws with the T5 head.
    • Unscrew the 5mm screws with the T5 head.
    • Unscrew the 6mm screw with the T6 head.
  6. Remove the black cover with the plastic opening tool. Remove the headphone jack from its slot.
    • Remove the black cover with the plastic opening tool.
    • Remove the headphone jack from its slot.
  7. Unplug the power cable by carefully prying it away from the motherboard. Unplug the power cable by carefully prying it away from the motherboard.
    • Unplug the power cable by carefully prying it away from the motherboard.
  8. Remove the power strip on the back side of the motherboard. Remove the power strip on the back side of the motherboard.
    • Remove the power strip on the back side of the motherboard.
  9. Remove the shield. Remove the shield.
    • Remove the shield.
  10. Push the screen through the front of the case, gently. It may be a little tough, just work your way around the edges of the screen until it separates from the main case.
    • Push the screen through the front of the case, gently.
    • It may be a little tough, just work your way around the edges of the screen until it separates from the main case.
Abschluss
4 weitere Nutzer haben diese Anleitung absolviert.
Alex Tobin
391 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 14-5, Leahy Fall 2014 Mitglied von USF Tampa, Team 14-5, Leahy Fall 2014
USFT-LEAHY-F14S14G5
3 Mitglieder
5 Anleitungen geschrieben
hi can you add explain
abdnour master2 - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 11
Insgesamt: 1,939
