Zum Hauptinhalt wechseln
Einleitung
This guide will show you how to remove the Dark Grey case that allows you access to the Motherboard.
Ersatzteile
Keine Ersatzteile angegeben.
  1. To remove the back cover, use your thumb to press down on the center of case and slide it off.
    • To remove the back cover, use your thumb to press down on the center of case and slide it off.
  2. Using a fingernail lift the battery out of the phone.
    • Using a fingernail lift the battery out of the phone.
  3. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  4. Slide the sim card out with your thumb.
    • Slide the sim card out with your thumb.
  5. To remove the back case first remove the four screws shown with a T5 Torx screwdriver
    • To remove the back case first remove the four screws shown with a T5 Torx screwdriver
  6. Using your fingernail lift up the side of the casing around the bottom of the phone to release all five of the clips.
    • Using your fingernail lift up the side of the casing around the bottom of the phone to release all five of the clips.
  7. Lift up towards the bottom and slide the case off.
    • Lift up towards the bottom and slide the case off.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Alex Serventi
50 Reputation
13 Anleitungen geschrieben
Cal Poly, Team 5-15, Maness Fall 2010 Mitglied von Cal Poly, Team 5-15, Maness Fall 2010
CPSU-MANESS-F10S5G15
4 Mitglieder
26 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 996
