Einleitung
This guide will show you how to remove the Dark Grey case that allows you access to the Screens.
Was du brauchst
To remove the front cover, lift up the case with a fingernail in the small slot as shown.
To remove the front grey case, remove the two screws shown with a T5 Torx Screwdriver.
Pry up the dark grey case with your fingernail until all four snaps around the top are loose.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
