Zum Hauptinhalt wechseln
Sony Ericsson z300 Microphone Replacement
Was du brauchst
  1. Sony Ericsson z300 Microphone Replacement, Back Phone Cover: Schritt 1, Bild 1 von 1
    • To remove the back cover, use your thumb to press down on the center of case and slide it off.
  2. Sony Ericsson z300 Microphone Replacement, Battery: Schritt 2, Bild 1 von 1
    • Using a fingernail lift the battery out of the phone.
  3. Sony Ericsson z300 Microphone Replacement, Sim Card: Schritt 3, Bild 1 von 1
    • Slide the sim card out with your thumb.
  4. Sony Ericsson z300 Microphone Replacement, Back Dark Grey Case: Schritt 4, Bild 1 von 1
    • To remove the back case first remove the four screws shown with a T5 Torx screwdriver
  5. Sony Ericsson z300 Microphone Replacement: Schritt 5, Bild 1 von 1
    • Using your fingernail lift up the side of the casing around the bottom of the phone to release all five of the clips.
  6. Sony Ericsson z300 Microphone Replacement: Schritt 6, Bild 1 von 1
    • Lift up towards the bottom and slide the case off.
  7. Sony Ericsson z300 Microphone Replacement, Motherboard: Schritt 7, Bild 1 von 1
    • Use a plastic opening tool to lift up the brass colored panel.
  8. Sony Ericsson z300 Microphone Replacement: Schritt 8, Bild 1 von 1
    • Flip up the yellow tab using a plastic opening tool to disconnect the motherboard from the phone body.
  9. Sony Ericsson z300 Microphone Replacement: Schritt 9, Bild 1 von 1
    • Work the plastic opening tool around the edges of the motherboard to release it from the clips.
  10. Sony Ericsson z300 Microphone Replacement, Keypad: Schritt 10, Bild 1 von 1
    • Using a plastic opening tool lift up the keypad to remove it.
  11. Sony Ericsson z300 Microphone Replacement, Microphone: Schritt 11, Bild 1 von 1
    • Use a plastic opening tool to lift the microphone out of its circular slot.
Abschluss
Alex Serventi
65 Reputation
13 Anleitungen geschrieben
Cal Poly, Team 5-15, Maness Fall 2010 Mitglied von Cal Poly, Team 5-15, Maness Fall 2010
CPSU-MANESS-F10S5G15
4 Mitglieder
26 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 10
Insgesamt: 1,883
