Zum Hauptinhalt wechseln
Sony Ericsson z300 Screens Replacement
Was du brauchst
  1. Sony Ericsson z300 Screens Replacement, Back Phone Cover: Schritt 1, Bild 1 von 1
    • To remove the back cover, use your thumb to press down on the center of case and slide it off.
  2. Sony Ericsson z300 Screens Replacement, Battery: Schritt 2, Bild 1 von 1
    • Using a fingernail lift the battery out of the phone.
  3. Sony Ericsson z300 Screens Replacement, Front Phone Cover: Schritt 3, Bild 1 von 1
    • To remove the front cover, lift up the case with a fingernail in the small slot as shown.
  4. Sony Ericsson z300 Screens Replacement, Front Dark Grey Case: Schritt 4, Bild 1 von 1
    • To remove the front grey case, remove the two screws shown with a T5 Torx Screwdriver.
  5. Sony Ericsson z300 Screens Replacement: Schritt 5, Bild 1 von 1
    • Pry up the dark grey case with your fingernail until all four snaps around the top are loose.
  6. Sony Ericsson z300 Screens Replacement: Schritt 6, Bild 1 von 1
    • Lift up towards the bottom and slide the case off.
  7. Sony Ericsson z300 Screens Replacement, Screens: Schritt 7, Bild 1 von 1
    • Use a plastic opening tool to lift the black tape off of the ribbon cable connector.
  8. Sony Ericsson z300 Screens Replacement: Schritt 8, Bild 1 von 1
    • Lift the ribbon cable connector lock using a plastic opening tool.
  9. Sony Ericsson z300 Screens Replacement: Schritt 9, Bild 1 von 2 Sony Ericsson z300 Screens Replacement: Schritt 9, Bild 2 von 2
    • Slide the black ribbon cable tray out with a plastic opening tool.
    • Shown in the second picture is the try already slid out.
  10. Sony Ericsson z300 Screens Replacement: Schritt 10, Bild 1 von 2 Sony Ericsson z300 Screens Replacement: Schritt 10, Bild 2 von 2
    • Slide the ribbon cable out of the connector.
    • Shown in the second picture is the cable already out.
  11. Sony Ericsson z300 Screens Replacement: Schritt 11, Bild 1 von 1
    • Use a plastic opening tool to lift up on the screen board and release the clips holding it in place.
    • Lift the entire board out of the phone to remove both screens.
Abschluss
Alex Serventi
65 Reputation
13 Anleitungen geschrieben
Cal Poly, Team 5-15, Maness Fall 2010 Mitglied von Cal Poly, Team 5-15, Maness Fall 2010
CPSU-MANESS-F10S5G15
4 Mitglieder
26 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 1,254
