Zum Hauptinhalt wechseln
Sony FDL-220R Watchman Button Replacement
Was du brauchst
  1. Sony FDL-220R Watchman Button Replacement, Remove battery cover and batteries: Schritt 1, Bild 1 von 2 Sony FDL-220R Watchman Button Replacement, Remove battery cover and batteries: Schritt 1, Bild 2 von 2
    • Press down on the textured area and push towards the bottom of the device.
    • Gently remove the battery cover.
    • Remove the three AA batteries.
  2. Sony FDL-220R Watchman Button Replacement, Remove screws: Schritt 2, Bild 1 von 2 Sony FDL-220R Watchman Button Replacement, Remove screws: Schritt 2, Bild 2 von 2
    • Locate the five 5x11mm screws surrounding the battery compartment.
    • Remove screws with a Philips #00 screwdriver.
  3. Sony FDL-220R Watchman Button Replacement, Remove back casing: Schritt 3, Bild 1 von 2 Sony FDL-220R Watchman Button Replacement, Remove back casing: Schritt 3, Bild 2 von 2
    • Grasp the entire back half of the Watchman's casing.
    • Snap off the casing from the bottom of the device.
    • Gently pull off entire back casing.
  4. Sony FDL-220R Watchman Button Replacement, Remove circuit board: Schritt 4, Bild 1 von 3 Sony FDL-220R Watchman Button Replacement, Remove circuit board: Schritt 4, Bild 2 von 3 Sony FDL-220R Watchman Button Replacement, Remove circuit board: Schritt 4, Bild 3 von 3
    • Carefully grasp the entire circuit board.
    • Pull the circuit board off of the device's plastic casing.
  5. Sony FDL-220R Watchman Button Replacement, Remove/Replace Buttons: Schritt 5, Bild 1 von 2 Sony FDL-220R Watchman Button Replacement, Remove/Replace Buttons: Schritt 5, Bild 2 von 2
    • Locate the thee plastic buttons/switches on the sides of the plastic grey casing.
    • Buttons/switches should be simply resting in their slots on the device.
    • Remove all three buttons/switches.
    • If the buttons/switches are dirty, clean them in warm water and dry thoroughly.
    • If one of the buttons/switches is broken, simply replace it with a new one.
    • When replacing, make sure that the slot on the switches faces up.
Abschluss
Sam Putnam
484 Reputation
4 Anleitungen geschrieben
Baylor, Team 4-5, Williams Fall 2014 Mitglied von Baylor, Team 4-5, Williams Fall 2014
BU-WILLIAMS-F14S4G5
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 240
