Was du brauchst
Remove the first screw located on the bottom of the LCD screen by using a cross tip screwdriver.
Turn the LCD screen either clockwise or counterclockwise for a better view of the screw.
Remove the second screw.
Remove each of the ribbon cables off by lifting up on the black tab.
Remove all ribbon cables before continuing unto the next step.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
