Zum Hauptinhalt wechseln
Sony Handycam DCR-SR 47 LCD Screen Replacement
Was du brauchst
  1. Sony Handycam DCR-SR 47 LCD Screen Replacement, Hard Drive: Schritt 1, Bild 1 von 1
    • Remove the battery.
    • Use Philips #000 screwdriver to remove the 3mm screw under the battery
    • *t is recommended that you wait One Hour after removing the battery before disassembling the rest of the camera
  2. Sony Handycam DCR-SR 47 LCD Screen Replacement: Schritt 2, Bild 1 von 1
    • Using the Phillips #000 screwdriver, remove all 6 of the 3mm screws located on the side of the camera.
    • This step seems unnecessary to initially find the Hard Drive, but will allow access to the attached flex cable
  3. Sony Handycam DCR-SR 47 LCD Screen Replacement: Schritt 3, Bild 1 von 1
    • Using the Phillips #000 tool, remove the three 3mm screws from under the LCD screen
  4. Sony Handycam DCR-SR 47 LCD Screen Replacement: Schritt 4, Bild 1 von 2 Sony Handycam DCR-SR 47 LCD Screen Replacement: Schritt 4, Bild 2 von 2
    • Using the Phillips #000 screwdriver, remove the one 3mm screw on the back of the camera
    • Pull away the back shell of the camera, exposing the hard drive.
  5. Sony Handycam DCR-SR 47 LCD Screen Replacement: Schritt 5, Bild 1 von 3 Sony Handycam DCR-SR 47 LCD Screen Replacement: Schritt 5, Bild 2 von 3 Sony Handycam DCR-SR 47 LCD Screen Replacement: Schritt 5, Bild 3 von 3
    • Gently pull the flex cable away from the hard drive. It should pop-off with minimal effort.
    • The black guard has been removed in the first picture. The guard does not need to be removed in order to reach hard drive and cable, but it does show the path that the cable takes
    • Once removing the flex cable, remove the plastic guard from the side of the hard drive.
  6. Sony Handycam DCR-SR 47 LCD Screen Replacement, LCD Screen: Schritt 6, Bild 1 von 2 Sony Handycam DCR-SR 47 LCD Screen Replacement, LCD Screen: Schritt 6, Bild 2 von 2
    • Insert wisdom here.
  7. Sony Handycam DCR-SR 47 LCD Screen Replacement: Schritt 7, Bild 1 von 2 Sony Handycam DCR-SR 47 LCD Screen Replacement: Schritt 7, Bild 2 von 2
  8. Sony Handycam DCR-SR 47 LCD Screen Replacement: Schritt 8, Bild 1 von 2 Sony Handycam DCR-SR 47 LCD Screen Replacement: Schritt 8, Bild 2 von 2
    • Using the plastic opening tool, separate the LCD screen from its plastic housing
  9. Sony Handycam DCR-SR 47 LCD Screen Replacement: Schritt 9, Bild 1 von 1
    • Using the spudger, or by gently pulling, remove the smaller end of the flex cable from the LCD Screen
  10. Sony Handycam DCR-SR 47 LCD Screen Replacement: Schritt 10, Bild 1 von 2 Sony Handycam DCR-SR 47 LCD Screen Replacement: Schritt 10, Bild 2 von 2
    • Using the Phillips #000 Screwdriver, remove the one 3mm screw from the LCD Scren
    • The LCD screen may now be removed from the camera completely.
  11. Sony Handycam DCR-SR 47 LCD Screen Replacement: Schritt 11, Bild 1 von 2 Sony Handycam DCR-SR 47 LCD Screen Replacement: Schritt 11, Bild 2 von 2
    • Take the LCD screen away from the housing and replace with new screen
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
where can i buy a screen for this camera?
Triforce Studios - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 1,148
