Einleitung
The LCD Screen is a crucial component to the playback of the camera. The camera will most likely take pictures if the LCD Screen is broken, but will be unable to show the pictures or setting options through the screen. If you wish to change the resolution settings on the camera, a broken or damaged LCD Screen must be fixed.
Was du brauchst
Remove the battery.
Use Philips #000 screwdriver to remove the 3mm screw under the battery
Using the Phillips #000 screwdriver, remove all 6 of the 3mm screws located on the side of the camera.
Using the Phillips #000 tool, remove the three 3mm screws from under the LCD screen
Using the Phillips #000 screwdriver, remove the one 3mm screw on the back of the camera
Pull away the back shell of the camera, exposing the hard drive.
Gently pull the flex cable away from the hard drive. It should pop-off with minimal effort.
Once removing the flex cable, remove the plastic guard from the side of the hard drive.
Using the plastic opening tool, separate the LCD screen from its plastic housing
Using the spudger, or by gently pulling, remove the smaller end of the flex cable from the LCD Screen
Using the Phillips #000 Screwdriver, remove the one 3mm screw from the LCD Scren
The LCD screen may now be removed from the camera completely.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
