Zum Hauptinhalt wechseln
Sony Handycam DCR-SR42 Hard Drive Replacement
Was du brauchst
  1. Sony Handycam DCR-SR42 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 2 Sony Handycam DCR-SR42 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 2 von 2
    • Remove the battery, and use the Phillips #00 precision screwdriver to then remove the three 3mm Phillips #00 screws under the battery.
    • Wait 1 hour after removing the battery before continuing to disassemble the camera.
  2. Sony Handycam DCR-SR42 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Remove the three 3mm #00 Phillips screws on the bottom of the camera.
  3. Sony Handycam DCR-SR42 Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Remove the three 3mm Phillips #00 screws on the side of the camera.
    • Remove the 4mm Phillips #00 screw under the AV port cover.
  4. Sony Handycam DCR-SR42 Hard Drive Replacement: Schritt 4, Bild 1 von 2 Sony Handycam DCR-SR42 Hard Drive Replacement: Schritt 4, Bild 2 von 2
    • Gently pull the black plastic hard drive cover away from the body of the camera. This will expose the hard drive.
    • Even with all the screws removed, this part will require some force to remove.
  5. Sony Handycam DCR-SR42 Hard Drive Replacement: Schritt 5, Bild 1 von 2 Sony Handycam DCR-SR42 Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Lift the hard drive out of the camera by grasping the grey rubber mounting brackets and pulling them upwards.
    • The hard drive is attached to the flex cable. Remove the hard drive slowly to prevent the flex cable from being damaged.
  6. Sony Handycam DCR-SR42 Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Remove the rubber mounting brackets by pulling them off the hard drive.
  7. Sony Handycam DCR-SR42 Hard Drive Replacement: Schritt 7, Bild 1 von 1
    • Carefully unplug the flex cable from the hard drive.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Dan Muller
1.020 Reputation
5 Anleitungen geschrieben
Baylor, Team 7-13, Williams Spring 2015 Mitglied von Baylor, Team 7-13, Williams Spring 2015
BU-WILLIAMS-S15S7G13
4 Mitglieder
10 Anleitungen geschrieben
2 Kommentare
Gracias por el post. Muy buenas las explicaciones.
Una consulta.
Tengo filmadora SONY DRC-SR21 cuyo disco original es Toshiba MKL8034GAL.
Puedo usar un disco de 30GB para reemplazarlo ?
Intenté hacerlo pero al encender la filmadora, vuelve a apagarse.
El disco original es de 500mA y el de 30GB es de 400mA.
Gracias por la ayuda
JORGE - Antwort
Hi, that’s a very comprehensive tutorial, well done!
I’m trying to find out if I can access video footage recorded onto a sony handycam ( DCR-SR75) The LCD screen stopped working and I can’t seem to operate the memory. I would appreciate any advise or suggestions as how to sort this problem thanks, Ger
Ger O'Neill - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 82
Insgesamt: 6,155
