Was du brauchst
In diesem Schritt verwendetes Werkzeug:Anti-Static Wrist Strap$7.95
Unfasten the hand strap.
Place device on left side with front lens facing right.
Using a JIS size #00 precision Phillips screwdriver, unscrew the left middle 3mm Phillips screw.
Open the "DC IN" plastic tab (Second 3mm Phillips screw is revealed).
Unscrew the second 3mm Phillips screw.
Turn device over onto its top with the front lens facing right.
Unscrew the top left and top right 3mm Philips screws.
While securely holding the HDD in your left hand, use the soft pad of your right hand fingers to gently pull the ribbon wire out of its socket, toward your right.
Replace HDD.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
2 Kommentare
Dónde puedo adquirir ese HDD?
Buenas, tardes. Necesito ese HDD. Dónde lo puedo conseguir.Soy de Perú. Gracias.
