Zum Hauptinhalt wechseln
Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement
Was du brauchst
  1. Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement, Hard Disk Drive (HDD): Schritt 1, Bild 1 von 1
    • Undo Hand Strap
    • Remove battery.
    • Get the iFixit screwdriver and remove the extension.
    • Use a JO Philips head bit.
  2. Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: Schritt 2, Bild 1 von 2 Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: Schritt 2, Bild 2 von 2
    • Place device on left side with lens facing right.
    • Using the screwdriver, unscrew the left middle 3mm Philips screw.
    • Open the "DC IN" tabe. (Second 3mm Philips screw is revealed)
    • Unscrew this screw.
  3. Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: Schritt 3, Bild 1 von 1
    • Turn device over onto it's top with the lens facing right.
    • Unscrew the top left and top right 3mm Philips screws.
    • The right side casing is now free.
  4. Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: Schritt 4, Bild 1 von 2 Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: Schritt 4, Bild 2 von 2
    • Remove the right side casing by pulling up and away.
    • The HDD is now revealed.
  5. Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: Schritt 5, Bild 1 von 3 Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: Schritt 5, Bild 2 von 3 Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: Schritt 5, Bild 3 von 3
    • Using your fingers, lift the HDD from it's right end, pivoting on it's left end.
    • The HDD ribbon wire is now exposed.
  6. Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: Schritt 6, Bild 1 von 2 Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: Schritt 6, Bild 2 von 2
    • Using your fingers, gently pull the ribbon wire out of it's socket.
    • The HDD is now free from the device.
  7. Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: Schritt 7, Bild 1 von 2 Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: Schritt 7, Bild 2 von 2
    • Using your fingers, pull the black rubber bumpers off of the HDD.
    • Set the old HDD aside.
Abschluss
17 weitere Nutzer:innen haben diese Anleitung absolviert.
7 Kommentare
Hi. Would you know if the hard drive of the sr67 would work in a sr 68? My sony handycam dcr sr67 Got water damage and I need to download videos. Can't find an old 67. 0nly 68. No one can fix the old one. Thanks renee
Renee - Antwort
What does the letter H after hte HDD1818 stands for?
guimoramirez - Antwort
My dcr-sr68 hdd not formting please find salution
Naman Jain - Antwort
My SONY HANDYCAM DCR - SR68 HDD FORMATING shows Error E:31.00
What does it mean ?
Daanish - Antwort
My sony handycam DCR-SR68 HDD not formating plz find
bharat kumar solanki - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 25
Letzte 30 Tage: 119
Insgesamt: 9,758
