Zum Hauptinhalt wechseln
Sony Handycam DCR-SR68 Speaker Replacement
Was du brauchst
  1. Sony Handycam DCR-SR68 Speaker Replacement, Speaker: Schritt 1, Bild 1 von 2 Sony Handycam DCR-SR68 Speaker Replacement, Speaker: Schritt 1, Bild 2 von 2
    • Remove battery before working on device.
    • Undo hand strap.
    • Get iFixit screwdriver and a JIOS Philips head bit.
  2. Sony Handycam DCR-SR68 Speaker Replacement: Schritt 2, Bild 1 von 2 Sony Handycam DCR-SR68 Speaker Replacement: Schritt 2, Bild 2 von 2
    • Place device on left side with lens facing right.
    • Using the screwdriver, unscrew the left middle screw.
    • Open the "DC IN" tab.
    • Second screw is revealed.
    • Unscrew this screw.
  3. Sony Handycam DCR-SR68 Speaker Replacement: Schritt 3, Bild 1 von 1
    • Turn device onto it's top with the lens facing right.
    • Unscrew the top left and top right screws.
    • Right side casing is now free.
  4. Sony Handycam DCR-SR68 Speaker Replacement: Schritt 4, Bild 1 von 2 Sony Handycam DCR-SR68 Speaker Replacement: Schritt 4, Bild 2 von 2
    • Remove the right side casing by pulling away.
    • HDD is now revealed.
  5. Sony Handycam DCR-SR68 Speaker Replacement: Schritt 5, Bild 1 von 3 Sony Handycam DCR-SR68 Speaker Replacement: Schritt 5, Bild 2 von 3 Sony Handycam DCR-SR68 Speaker Replacement: Schritt 5, Bild 3 von 3
    • Using your fingers, lift the HDD by it's right end, pivoting on it's left end.
    • HDD ribbon wire is now exposed.
  6. Sony Handycam DCR-SR68 Speaker Replacement: Schritt 6, Bild 1 von 2 Sony Handycam DCR-SR68 Speaker Replacement: Schritt 6, Bild 2 von 2
    • Using your fingers, pull the ribbon wire out of it's socket.
    • HDD is now free from device.
    • Set HDD aside
  7. Sony Handycam DCR-SR68 Speaker Replacement: Schritt 7, Bild 1 von 2 Sony Handycam DCR-SR68 Speaker Replacement: Schritt 7, Bild 2 von 2
    • Using your fingers, remove the A/V tab.
  8. Sony Handycam DCR-SR68 Speaker Replacement: Schritt 8, Bild 1 von 3 Sony Handycam DCR-SR68 Speaker Replacement: Schritt 8, Bild 2 von 3 Sony Handycam DCR-SR68 Speaker Replacement: Schritt 8, Bild 3 von 3
    • On the bottom of the device, unscrew the right and middle bottom 3mm Philips screws.
    • Remove panel.
  9. Sony Handycam DCR-SR68 Speaker Replacement: Schritt 9, Bild 1 von 2 Sony Handycam DCR-SR68 Speaker Replacement: Schritt 9, Bild 2 von 2
    • Using the screwdriver, unscrew the top two black 3mm Philips screws.
    • Lift out the grey tray, being careful when feeding the large ribbon wire though the slot.
  10. Sony Handycam DCR-SR68 Speaker Replacement: Schritt 10, Bild 1 von 2 Sony Handycam DCR-SR68 Speaker Replacement: Schritt 10, Bild 2 von 2
    • Using the black pointed spudger, carefully pop op the latch on the large ribbon wire's port.
    • Set large ribbon wire aside.
  11. Sony Handycam DCR-SR68 Speaker Replacement: Schritt 11, Bild 1 von 3 Sony Handycam DCR-SR68 Speaker Replacement: Schritt 11, Bild 2 von 3 Sony Handycam DCR-SR68 Speaker Replacement: Schritt 11, Bild 3 von 3
    • Using the blunt tweezers, unplug the red and black wires.
    • Using the blunt tweezers, unplug the small ribbon wire.
  12. Sony Handycam DCR-SR68 Speaker Replacement: Schritt 12, Bild 1 von 1
    • Unscrew the top 3 3mm Philips screws from right to left.
  13. Sony Handycam DCR-SR68 Speaker Replacement: Schritt 13, Bild 1 von 1
    • On the back of the device, unscrew the top 3mm Philips screw.
  14. Sony Handycam DCR-SR68 Speaker Replacement: Schritt 14, Bild 1 von 2 Sony Handycam DCR-SR68 Speaker Replacement: Schritt 14, Bild 2 von 2
    • On the left side of the device, unscrew the top 2 3mm Philips screws.
    • The top of the device is now free.
  15. Sony Handycam DCR-SR68 Speaker Replacement: Schritt 15, Bild 1 von 2 Sony Handycam DCR-SR68 Speaker Replacement: Schritt 15, Bild 2 von 2
    • Remove the top of the device by lifting it upwards.
    • Be careful of the wires becoming snagged on the frame.
  16. Sony Handycam DCR-SR68 Speaker Replacement: Schritt 16, Bild 1 von 3 Sony Handycam DCR-SR68 Speaker Replacement: Schritt 16, Bild 2 von 3 Sony Handycam DCR-SR68 Speaker Replacement: Schritt 16, Bild 3 von 3
    • With the top of the device in hand, remove the 4 visible 3mm Philips screws.
    • Remove the frame by lifting away.
  17. Sony Handycam DCR-SR68 Speaker Replacement: Schritt 17, Bild 1 von 2 Sony Handycam DCR-SR68 Speaker Replacement: Schritt 17, Bild 2 von 2
    • The speaker is the object on the right with a ribbon wire connecting to it.
    • Remove the broken speaker with your fingers.
    • Replace with new speaker.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 294
