Einleitung
Can't listen to recording with scratchy or without sound! Follow this speaker replacement guide to once again be able to listen those recordings.
Was du brauchst
Place device on left side with lens facing right.
Using the screwdriver, unscrew the left middle screw.
Open the "DC IN" tab.
Unscrew this screw.
Turn device onto it's top with the lens facing right.
Unscrew the top left and top right screws.
On the bottom of the device, unscrew the right and middle bottom 3mm Philips screws.
Remove panel.
Using the screwdriver, unscrew the top two black 3mm Philips screws.
Lift out the grey tray, being careful when feeding the large ribbon wire though the slot.
Using the black pointed spudger, carefully pop op the latch on the large ribbon wire's port.
Set large ribbon wire aside.
Using the blunt tweezers, unplug the red and black wires.
Using the blunt tweezers, unplug the small ribbon wire.
With the top of the device in hand, remove the 4 visible 3mm Philips screws.
Remove the frame by lifting away.
