Einleitung
This guide will help you if your LCD screen is malfunctioning. Be wary the screen is the most difficult part to remove so be cautious as you take apart each piece of the camera.
Was du brauchst
Remove the six black 4 mm Phillips #00 screws from the bottom panel of the camera.
Pull off the bottom panel. It may be difficult, but tugging on it shouldn't cause harm to yourself or the device.
Remove the 3 mm Phillips #00 screw from the bottom of the camera.
Remove the 4 mm Phillips #00 screw from the right panel.
Pull the right panel off. Again, it might be difficult, but pulling hard shouldn't harm you or the camera.
Remove the two 4 mm Phillips #00 screws from the top right corner of the camera.
Remove the 4 mm Phillips #00 screw from in front of the flash mount.
Remove the 3 mm Phillips #00 screw from below the right side of the battery slot.
Remove the black 5 mm Phillips #00 screw from the top of the battery slot.
Remove the three 4 mm Phillips #00 screws from the left panel underneath the display screen.
Pull the top panel off of the device with the iFixit opening tool.
Remove the top and bottom 4 mm Phillips #00 screws from the display screen hinge.
Use the iFixit opening tool to remove the screen hinge.
Remove the 3 mm Phillips #00 screw from between the eyepiece and the panel directly to the right of the battery slot.
Take the panel directly to the right of the battery slot off of the camera.
Remove the 4 mm Phillips #00 screw above and to the right of the battery slot.
Pry the left panel out at an angle by pushing the plastic slat between the battery slot and the eyepiece.
Wiggle the left panel and pull it out gently.
Remove the black 3 mm Phillips #00 screw from the middle of the hinge.
Remove the two 4 mm Phillips #00 screws from the inside of the screen hinge.
Remove the PCB copper circuits from the blue circuit board by pulling out the flexible plastic connector.
Remove the two 4 mm Phillips #00 screws from both sides of the connection between the hinge and the screen.
With the the screen flipped out, pull the screen towards the back of the camera to remove the screen.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
e:61:30 error
I need the PCB behind the LCD. One of the ICs in the top right quadrant was sheared off. any idea other than ebay or pawn shops for salvage electronics?
Thanks in advance!
Please can you tell me where to purchase Sony Handycam FDR-AX33 LCD Screen?
mfelizardo@gmail.com
Portugal
