Zum Hauptinhalt wechseln
Sony Handycam HDR­-CX220 Buttons Replacement
Was du brauchst
  1. Sony Handycam HDR­-CX220 Buttons  Replacement, Battery: Schritt 1, Bild 1 von 1
    • Push in the battery indicator.
  2. Sony Handycam HDR­-CX220 Buttons  Replacement: Schritt 2, Bild 1 von 1
    • Slide the battery out of the slot.
    • To put the battery back in, line up the battery's metal part with the camera's and slide it in.
  3. Sony Handycam HDR­-CX220 Buttons  Replacement, Camera's Body: Schritt 3, Bild 1 von 3 Sony Handycam HDR­-CX220 Buttons  Replacement, Camera's Body: Schritt 3, Bild 2 von 3 Sony Handycam HDR­-CX220 Buttons  Replacement, Camera's Body: Schritt 3, Bild 3 von 3
    • Use the Phillips #0 screwdriver to remove the two 5mm screws.
    • Use the Phillips #0 screwdriver to remove the three 5mm screws.
  4. Sony Handycam HDR­-CX220 Buttons  Replacement: Schritt 4, Bild 1 von 3 Sony Handycam HDR­-CX220 Buttons  Replacement: Schritt 4, Bild 2 von 3 Sony Handycam HDR­-CX220 Buttons  Replacement: Schritt 4, Bild 3 von 3
    • Use the plastic opening tool to loosen the plastic case of the camcorder.
  5. Sony Handycam HDR­-CX220 Buttons  Replacement: Schritt 5, Bild 1 von 1
    • Use your hands to remove the plastic case.
    • Gently pull on the case not to damage anything internally.
  6. Sony Handycam HDR­-CX220 Buttons  Replacement, Buttons: Schritt 6, Bild 1 von 3 Sony Handycam HDR­-CX220 Buttons  Replacement, Buttons: Schritt 6, Bild 2 von 3 Sony Handycam HDR­-CX220 Buttons  Replacement, Buttons: Schritt 6, Bild 3 von 3
    • Use the Philips #0 screwdriver to unscrew the two 5mm screws shown on top of the camera.
    • Remove the one side 5mm screw using a Philips #0 Screwdriver.
    • Remove the top buttons from the hook.
  7. Sony Handycam HDR­-CX220 Buttons  Replacement: Schritt 7, Bild 1 von 2 Sony Handycam HDR­-CX220 Buttons  Replacement: Schritt 7, Bild 2 von 2
    • Unplug the connected wire shown.
    • Pull gently not to cause any damage.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Keven
811 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team 8-5, Botvin Spring 2016 Mitglied von UMass Dartmouth, Team 8-5, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G5
3 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
hi, can you please tell me where can I buyStep 6 Buttons?
thanks
jesus - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 892
