Zum Hauptinhalt wechseln
Sony Handycam HDR­-CX220 Display Screen Replacement
Was du brauchst
  1. Sony Handycam HDR­-CX220 Display Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Push in the battery indicator.
  2. Sony Handycam HDR­-CX220 Display Screen Replacement: Schritt 2, Bild 1 von 1
    • Slide the battery out of the slot.
    • To put the battery back in, line up the battery's metal part with the camera's and slide it in.
  3. Sony Handycam HDR­-CX220 Display Screen Replacement, Camera's Body: Schritt 3, Bild 1 von 3 Sony Handycam HDR­-CX220 Display Screen Replacement, Camera's Body: Schritt 3, Bild 2 von 3 Sony Handycam HDR­-CX220 Display Screen Replacement, Camera's Body: Schritt 3, Bild 3 von 3
    • Use the Phillips #0 screwdriver to remove the two 5mm screws.
    • Use the Phillips #0 screwdriver to remove the three 5mm screws.
  4. Sony Handycam HDR­-CX220 Display Screen Replacement: Schritt 4, Bild 1 von 3 Sony Handycam HDR­-CX220 Display Screen Replacement: Schritt 4, Bild 2 von 3 Sony Handycam HDR­-CX220 Display Screen Replacement: Schritt 4, Bild 3 von 3
    • Use the plastic opening tool to loosen the plastic case of the camcorder.
  5. Sony Handycam HDR­-CX220 Display Screen Replacement: Schritt 5, Bild 1 von 1
    • Use your hands to remove the plastic case.
    • Gently pull on the case not to damage anything internally.
  6. Sony Handycam HDR­-CX220 Display Screen Replacement, Display Screen: Schritt 6, Bild 1 von 2 Sony Handycam HDR­-CX220 Display Screen Replacement, Display Screen: Schritt 6, Bild 2 von 2
    • Use the Phillips #0 screwdriver to remover the two (5mm) screws on the outer part and one (3mm) in the middle.
    • In the second image, there is a second screw on the opposite side of the screen hinge. This screw is not shown, but must also be removed.
  7. Sony Handycam HDR­-CX220 Display Screen Replacement: Schritt 7, Bild 1 von 1
    • Use the plastic opening tool to remove the plastic case protecting the screen
    • Pull it gently not to damage anything under the case
  8. Sony Handycam HDR­-CX220 Display Screen Replacement: Schritt 8, Bild 1 von 2 Sony Handycam HDR­-CX220 Display Screen Replacement: Schritt 8, Bild 2 von 2
    • Use the Phillips #0 screwdriver to remove the 2 screws shown
    • Use your hands to carefully unhook the screen from the highlighted hook
  9. Sony Handycam HDR­-CX220 Display Screen Replacement: Schritt 9, Bild 1 von 3 Sony Handycam HDR­-CX220 Display Screen Replacement: Schritt 9, Bild 2 von 3 Sony Handycam HDR­-CX220 Display Screen Replacement: Schritt 9, Bild 3 von 3
    • Use your hands to carefully remove the tape
    • After removing the tape, pull on the wire disconnecting it from the screen.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Keven
811 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team 8-5, Botvin Spring 2016 Mitglied von UMass Dartmouth, Team 8-5, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G5
3 Mitglieder
12 Anleitungen geschrieben
3 Kommentare
How do you mount hdr cx220 lcd cable flat? can you help me?
Rafael Oliveira - Antwort
gjhgvnvyh n hygfv
ANM WORLD - Antwort
We have a camera 220. Whose dipstick display strip has deteriorated again. Where can I find this strip? Video is good information so that's why
ANM WORLD - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 21
Insgesamt: 2,493
