Einleitung
The replacement of the screen is needed if the image on the screen is not the desired image or if the screen is physically damaged.
Was du brauchst
Use the Phillips #0 screwdriver to remove the two 5mm screws.
Use the Phillips #0 screwdriver to remove the three 5mm screws.
Use the Phillips #0 screwdriver to remover the two (5mm) screws on the outer part and one (3mm) in the middle.
In the second image, there is a second screw on the opposite side of the screen hinge. This screw is not shown, but must also be removed.
Use the Phillips #0 screwdriver to remove the 2 screws shown
Use your hands to carefully unhook the screen from the highlighted hook
Use your hands to carefully remove the tape
After removing the tape, pull on the wire disconnecting it from the screen.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
How do you mount hdr cx220 lcd cable flat? can you help me?
