Zum Hauptinhalt wechseln
Sony Handycam HDR­-CX220 Lens Replacement
Was du brauchst
  1. Sony Handycam HDR­-CX220 Lens Replacement, Battery: Schritt 1, Bild 1 von 1
    • Push in the battery indicator.
  2. Sony Handycam HDR­-CX220 Lens Replacement: Schritt 2, Bild 1 von 1
    • Slide the battery out of the slot.
    • To put the battery back in, line up the battery's metal part with the camera's and slide it in.
  3. Sony Handycam HDR­-CX220 Lens Replacement, Camera's Body: Schritt 3, Bild 1 von 3 Sony Handycam HDR­-CX220 Lens Replacement, Camera's Body: Schritt 3, Bild 2 von 3 Sony Handycam HDR­-CX220 Lens Replacement, Camera's Body: Schritt 3, Bild 3 von 3
    • Use the Phillips #0 screwdriver to remove the two 5mm screws.
    • Use the Phillips #0 screwdriver to remove the three 5mm screws.
  4. Sony Handycam HDR­-CX220 Lens Replacement: Schritt 4, Bild 1 von 3 Sony Handycam HDR­-CX220 Lens Replacement: Schritt 4, Bild 2 von 3 Sony Handycam HDR­-CX220 Lens Replacement: Schritt 4, Bild 3 von 3
    • Use the plastic opening tool to loosen the plastic case of the camcorder.
  5. Sony Handycam HDR­-CX220 Lens Replacement: Schritt 5, Bild 1 von 1
    • Use your hands to remove the plastic case.
    • Gently pull on the case not to damage anything internally.
  6. Sony Handycam HDR­-CX220 Lens Replacement, Lens: Schritt 6, Bild 1 von 3 Sony Handycam HDR­-CX220 Lens Replacement, Lens: Schritt 6, Bild 2 von 3 Sony Handycam HDR­-CX220 Lens Replacement, Lens: Schritt 6, Bild 3 von 3
    • Use the Phillips #0 Screwdriver to remove the 5mm screw
    • Use the Plastic Opening tools to unhook the highlighted area.
  7. Sony Handycam HDR­-CX220 Lens Replacement: Schritt 7, Bild 1 von 1
    • Remove the 3 (4mm) screws on the front of the lens using the Philips #0 Screwdriver.
  8. Sony Handycam HDR­-CX220 Lens Replacement: Schritt 8, Bild 1 von 1
    • Remove the lens and clean it if needed.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Keven
811 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team 8-5, Botvin Spring 2016 Mitglied von UMass Dartmouth, Team 8-5, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G5
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 7
Letzte 30 Tage: 13
Insgesamt: 728
