Zum Hauptinhalt wechseln
Sony Handycam HDR­-CX220 Motherboard Replacement
Was du brauchst
  1. Sony Handycam HDR­-CX220 Motherboard  Replacement, Battery: Schritt 1, Bild 1 von 1
    • Push in the battery indicator.
  2. Sony Handycam HDR­-CX220 Motherboard  Replacement: Schritt 2, Bild 1 von 1
    • Slide the battery out of the slot.
    • To put the battery back in, line up the battery's metal part with the camera's and slide it in.
  3. Sony Handycam HDR­-CX220 Motherboard  Replacement, Camera's Body: Schritt 3, Bild 1 von 3 Sony Handycam HDR­-CX220 Motherboard  Replacement, Camera's Body: Schritt 3, Bild 2 von 3 Sony Handycam HDR­-CX220 Motherboard  Replacement, Camera's Body: Schritt 3, Bild 3 von 3
    • Use the Phillips #0 screwdriver to remove the two 5mm screws.
    • Use the Phillips #0 screwdriver to remove the three 5mm screws.
  4. Sony Handycam HDR­-CX220 Motherboard  Replacement: Schritt 4, Bild 1 von 3 Sony Handycam HDR­-CX220 Motherboard  Replacement: Schritt 4, Bild 2 von 3 Sony Handycam HDR­-CX220 Motherboard  Replacement: Schritt 4, Bild 3 von 3
    • Use the plastic opening tool to loosen the plastic case of the camcorder.
  5. Sony Handycam HDR­-CX220 Motherboard  Replacement: Schritt 5, Bild 1 von 1
    • Use your hands to remove the plastic case.
    • Gently pull on the case not to damage anything internally.
  6. Sony Handycam HDR­-CX220 Motherboard  Replacement, Lens: Schritt 6, Bild 1 von 3 Sony Handycam HDR­-CX220 Motherboard  Replacement, Lens: Schritt 6, Bild 2 von 3 Sony Handycam HDR­-CX220 Motherboard  Replacement, Lens: Schritt 6, Bild 3 von 3
    • Use the Phillips #0 Screwdriver to remove the 5mm screw
    • Use the Plastic Opening tools to unhook the highlighted area.
  7. Sony Handycam HDR­-CX220 Motherboard  Replacement: Schritt 7, Bild 1 von 1
    • Remove the 3 (4mm) screws on the front of the lens using the Philips #0 Screwdriver.
  8. Sony Handycam HDR­-CX220 Motherboard  Replacement: Schritt 8, Bild 1 von 1
    • Remove the lens and clean it if needed.
  9. Sony Handycam HDR­-CX220 Motherboard  Replacement, Motherboard: Schritt 9, Bild 1 von 3 Sony Handycam HDR­-CX220 Motherboard  Replacement, Motherboard: Schritt 9, Bild 2 von 3 Sony Handycam HDR­-CX220 Motherboard  Replacement, Motherboard: Schritt 9, Bild 3 von 3
    • Use the Phillips #0 Screwdriver to remove the shown 5mm screws.
    • Use the plastic opening tool to release the front hook.
    • Use the plastic opening tool to release the back hook.
  10. Sony Handycam HDR­-CX220 Motherboard  Replacement: Schritt 10, Bild 1 von 2 Sony Handycam HDR­-CX220 Motherboard  Replacement: Schritt 10, Bild 2 von 2
    • Gently pull on the 2 wires shown on the bottom of the camcorder.
    • Disconnect the wire shows on the second picture.
  11. Sony Handycam HDR­-CX220 Motherboard  Replacement: Schritt 11, Bild 1 von 2 Sony Handycam HDR­-CX220 Motherboard  Replacement: Schritt 11, Bild 2 von 2
    • Use the Phillips #0 screwdriver to remove the 4mm screw shown.
    • Gently remove the motherboard with your fingers.
  12. Sony Handycam HDR­-CX220 Motherboard  Replacement: Schritt 12, Bild 1 von 2 Sony Handycam HDR­-CX220 Motherboard  Replacement: Schritt 12, Bild 2 von 2
    • Remove the side wire from the motherboard as shown on the photo.
    • Remove the top wire from the motherboard as shown on the photo.
  13. Sony Handycam HDR­-CX220 Motherboard  Replacement: Schritt 13, Bild 1 von 2 Sony Handycam HDR­-CX220 Motherboard  Replacement: Schritt 13, Bild 2 von 2
    • Unplug the speaker from the motherboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Keven
811 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team 8-5, Botvin Spring 2016 Mitglied von UMass Dartmouth, Team 8-5, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G5
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 1,040
