Einleitung
Use this guide to help you remove the broken or defected motherboard in your Sony Handycam HDR-Cx220.
Was du brauchst
Use the Phillips #0 screwdriver to remove the two 5mm screws.
Use the Phillips #0 screwdriver to remove the three 5mm screws.
Use the Phillips #0 Screwdriver to remove the 5mm screw
Use the Plastic Opening tools to unhook the highlighted area.
Remove the 3 (4mm) screws on the front of the lens using the Philips #0 Screwdriver.
Use the Phillips #0 Screwdriver to remove the shown 5mm screws.
Use the plastic opening tool to release the front hook.
Use the plastic opening tool to release the back hook.
Gently pull on the 2 wires shown on the bottom of the camcorder.
Disconnect the wire shows on the second picture.
Remove the side wire from the motherboard as shown on the photo.
Remove the top wire from the motherboard as shown on the photo.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
