Einleitung
Removing the battery is something that can be done by hand and should only take a few seconds to complete. Be sure to exercise care when removing it to avoid damaging the camera or injuring yourself.
Rotate your camera such that the underside is facing you and the lens is facing the ground.
Using your right index finger and thumb, pull the battery toward you and then away from the camera.
To insert a new battery or reinsert the one you removed, simply follow step 3 in reverse order and rotate the camera as described in step 1.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
