Einleitung
Removing the camera shell is an easy task that can be done in a couple of minutes.
Was du brauchst
Rotate your camera such that the underside is facing you and the lens is facing the ground.
Using your right index finger and thumb, pull the battery toward you and then away from the camera.
Remove the single 4.5 mm Phillips #00 screw.
Remove the single 5.5 mm Phillips #00 screw.
With the blue plastic opening tools, gently pry the plastic casing surrounding the start/stop button free.
Remove the casing using your right thumb and index finger.
Flip open the LCD panel to get to the side panel.
Remove the three 5.5 mm Phillips #00 screws.
Turn the camera around to the grip side and remove the 5.5 mm Phillips Head screw using your J00 Phillips Head screwdriver.
With the bottom of the camera facing up, remove the two 5.5mm Phillips #00 screws.
Orient the camera so the bottom is facing you.
Use the blue plastic opening tools to gently ease the camera shell off of the camera.
Rotate the camera so the LCD side panel is facing you and gently pry the shell off from the camera.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
