Zum Hauptinhalt wechseln
Sony Handycam HDR-CX405 Battery Replacement
  1. Sony Handycam HDR-CX405 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place thumb on the ridge of the battery door hatch.
    • Apply pressure horizontally to easily slide the door off.
  2. Sony Handycam HDR-CX405 Battery Replacement: Schritt 2, Bild 1 von 1
    • Using your thumb, push the small blue fastening clip down.
    • Slide old battery out of camera.
    • Release the blue fastening clip.
  3. Sony Handycam HDR-CX405 Battery Replacement: Schritt 3, Bild 1 von 1
    • Slide the new battery into the camera.
  4. Sony Handycam HDR-CX405 Battery Replacement: Schritt 4, Bild 1 von 1
    • Push battery door down so it is level with the original positioning.
    • Slide door shut.
Abschluss
Improper seating of the battery can lead to memory loss and even corruption, replacing a battery can be a simple way to solve sudden crashes of the device.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
UMass Dartmouth, Team 3-6, Bhusal Spring 2016 Mitglied von UMass Dartmouth, Team 3-6, Bhusal Spring 2016
UMASSD-BHUSAL-S16S3G6
3 Mitglieder
2 Anleitungen geschrieben
Ein Kommentar
What is that 2nd battery bay? There is a way of opening it?
Edmundo - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 41
Insgesamt: 3,610
