Einleitung
These instructions will guide you step-by-step to remove the door in order to get to the speakers inside
Was du brauchst
Pull on tab away from the camera by applying pressure with index finger.
Place the camera on a flat service, so that the strap is downward and the lens is facing you.
First, lift up the connector.
Then pull it back.
Remove the connector from the device.
Position the camera so that the screen tab is pointing towards you.
Twist the tab clockwise one notch.
Remove the single screw.
Place the camera so that the lens is facing downward and the battery compartment is facing towards you.
Lay the device on its side so it is resting on the strap and the bottom of the camera is facing you.
Remove the five screws.
Close the LCD screen door.
Turn the camera to the eye piece and battery compartment is facing you.
Your door will now be disassembled in order to replace parts inside and these steps in reverse order will also help you put the door back together
