Einleitung
Use this guide to replace the screen of a Sony ICF-C1T. When your screen is too bright or it has a lot of scratches on it, you can easily replace the screen or add a sheet of tint to the backside of it.
Was du brauchst
Use a Phillips 00 head screwdriver to remove the four 14 mm screws from the bottom of the clock.
Insert the plastic opening tool to pry apart the top and sides of the device gently.
Pull the top of the device away from the rest of the clock to expose the inside.
Add pressure to the inside of the screen so that a small area is loosened enough to be able to use an opening tool.
Use the plastic opening tool to separate the screen from the device.
Apply a tinted spray to dim the brightness once the tinted sheet is out of the way.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
