Zum Hauptinhalt wechseln
Sony ICF-C1T Volume Dial Replacement
Was du brauchst
  1. Sony ICF-C1T Volume Dial Replacement, Volume Dial: Schritt 1, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Phillips #0 Screwdriver
    $5.49
    Kaufen
    • Remove the 4 (14mm) screws from the underside of the device using the Philips #0 Screwdriver.
    • Before beginning this step, make sure the clock is unplugged and the batteries have been removed.
  2. Sony ICF-C1T Volume Dial Replacement: Schritt 2, Bild 1 von 1
    iFixit Opening Tool
    $1.99
    Kaufen
    • Pry apart the edge of the top and side portions of the device using a flat-headed tool (i.e. flathead screwdriver, card, etc)
    • It is recommended to use the iFixit Opening Tools for optimal removal.
  3. Sony ICF-C1T Volume Dial Replacement: Schritt 3, Bild 1 von 2 Sony ICF-C1T Volume Dial Replacement: Schritt 3, Bild 2 von 2
    • Carefully separate the device by gently pulling up on the top of the clock/radio.
    • Use caution when pulling the top of the clock; the clock display is located directly behind the faceplate and still connected by multiple wires.
  4. Sony ICF-C1T Volume Dial Replacement: Schritt 4, Bild 1 von 2 Sony ICF-C1T Volume Dial Replacement: Schritt 4, Bild 2 von 2
    • To remove the motherboard, gently pull apart the sides of the device.
    • Do not pull hard on the motherboard, as it is still connected by multiple wires inside the device.
    • Be careful of sharp pieces.
    • It would be helpful, although not necessary, to have someone helping out with this step.
  5. Sony ICF-C1T Volume Dial Replacement: Schritt 5, Bild 1 von 2 Sony ICF-C1T Volume Dial Replacement: Schritt 5, Bild 2 von 2
    • Remove the volume dial by pulling it off the motherboard. This can take a little force to remove.
Abschluss
Ein Kommentar
thanks for the great instructions. a few notes: it seems the “edit” comments were all left in above (“no edits necessary” and the stuff about highlighting parts of it). after step 3, there wasn’t instructions about removing the two screws from the motherboard, before step 4.
J Kwan - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 12
Insgesamt: 1,265
