Einleitung
If your clock display doesn't show a time or it doesn't provide any sort of display on your Sony ICF-C1PMK2, this guide provides step by step instructions on replacing the clock display. The clock display shows the time and tells you the radio station.
Was du brauchst
Flip product over to see the back.
Remove the 1 cm Phillips #00 screws.
Use a plastic spudger to pry the back chassis off of the front.
Open up the back.
Carefully remove the ribbon cables by pulling them straight out of the port.
Remove the 1 cm screws from the plastic speaker cover using Phillips #00 screwdriver.
Gently pull the speaker cable out.
Remove the plastic speaker cover from the left side.
Remove the two 1 cm Phillips #00 screws.
Carefully pull out the ribbon cable.
Slide the iPod dock out.
2 weitere Personen haben diese Anleitung absolviert.
