Einleitung
The speakers of the device allow you to listen for your favorite songs and hear your alarm in the morning. If you hear a crackling sound or no sound at all, follow these steps to replace the speaker.
Was du brauchst
Unscrew the 1 cm Phillips #00 screws.
Use spudger to loosen the back panel of the device.
Slowly pull the back panel off until it separated from the main panel.
Carefully unplug all of the ribbon cables connecting the back panel to the main panel.
Remove the power connector with a pair of ESD safe tweezers.
Remove the Aux port connector with a pair of ESD safe tweezers.
Slide the button panels out of the chassis.
Unscrew the four 1 cm Phillips #00 screws and remove the speaker cover.
Unscrew the 1 cm Phillips #00 screws holding the speaker in place.
Remove the old speaker and insert the new one.
