Was du brauchst
Find the arrow on the battery cover on the back of the device.
While pressing down on the arrow, slide the cover towards the bottom of the recorder until it clicks.
Remove the battery cover by first tilting it so it is at a right angle with the rest of the device.
Next, twist it to the side as shown in the second picture. The lid should simply snap off.
Use a #00 Phillips head screwdriver to remove the four (1.7x16 mm) screws from the back case.
Next, use the same screwdriver to unscrew the (1.7X5 mm) screw, which is located inside the battery compartment.
With a firm grip on the larger half, remove the back cover by lifting first on the battery area.
A black and a red wire connect the microphone to the motherboard as shown in the bottom left of the picture.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
The wires are held down with a piece of black tape.
Remove the tape with a pair of tweezers.
Desolder the two connections between the wires and the motherboard. Make sure that the two solder points do not melt together.
Now that the wires are disconnected from the motherboard, you can simply pull the mic out, away from the top of the device.
