Zum Hauptinhalt wechseln
Sony M-430 Microcassette-Corder Speaker Replacement
Was du brauchst
    1. Sony M-430 Microcassette-Corder Speaker Replacement, Battery: Schritt 1, Bild 1 von 1
      • Find the arrow on the battery cover on the back of the device.
      • While pressing down on the arrow, slide the cover towards the bottom of the recorder until it clicks.
      Frag FixBot
      Kommentar hinzufügen
    2. Sony M-430 Microcassette-Corder Speaker Replacement: Schritt 2, Bild 1 von 2 Sony M-430 Microcassette-Corder Speaker Replacement: Schritt 2, Bild 2 von 2
      • Lift the cover and remove the batteries.
      Frag FixBot
    1. Sony M-430 Microcassette-Corder Speaker Replacement, Back Cover: Schritt 3, Bild 1 von 2 Sony M-430 Microcassette-Corder Speaker Replacement, Back Cover: Schritt 3, Bild 2 von 2
      • Remove the battery cover by first tilting it so it is at a right angle with the rest of the device.
      • Next, twist it to the side as shown in the second picture. The lid should simply snap off.
      • Potential for device damage: be careful not to apply too much force, as the lid may break.
      Frag FixBot
    2. Sony M-430 Microcassette-Corder Speaker Replacement: Schritt 4, Bild 1 von 2 Sony M-430 Microcassette-Corder Speaker Replacement: Schritt 4, Bild 2 von 2
      • Use a #00 Phillips head screwdriver to remove the four (1.7x16 mm) screws from the back case.
      • Next, use the same screwdriver to unscrew the (1.7X5 mm) screw, which is located inside the battery compartment.
      Frag FixBot
    3. Sony M-430 Microcassette-Corder Speaker Replacement: Schritt 5, Bild 1 von 1
      • Use a spudger to push in the two tabs located on the bottom of the device.
      • It works best to push the tabs at an upward angle (towards the top of the battery compartment). It may take a decent amount of force in order to push in the tabs.
      Frag FixBot
    4. Sony M-430 Microcassette-Corder Speaker Replacement: Schritt 6, Bild 1 von 1
      • With a firm grip on the larger half, remove the back cover by lifting first on the battery area.
      • The back cover should lift cleanly off.
      Frag FixBot
    1. Sony M-430 Microcassette-Corder Speaker Replacement, Speaker: Schritt 7, Bild 1 von 1
      • The speaker is the large gold circular piece attached under where the batteries would normally be.
      • It is connected to the device with two black wires that run along one side of the motherboard, as shown on the top of the picture.
      Frag FixBot
    2. Sony M-430 Microcassette-Corder Speaker Replacement: Schritt 8, Bild 1 von 2 Sony M-430 Microcassette-Corder Speaker Replacement: Schritt 8, Bild 2 von 2
      • Depending on the replacement speaker you have, there are two places you can desolder the wire.
      • If your replacement speaker has a wire already attached to it, desolder the old wire from where it connects to the motherboard.
      • If the replacement speaker has no wire, desolder the old wire where it connects to the broken speaker.
      Frag FixBot
    3. Sony M-430 Microcassette-Corder Speaker Replacement: Schritt 9, Bild 1 von 2 Sony M-430 Microcassette-Corder Speaker Replacement: Schritt 9, Bild 2 von 2
      In diesem Schritt verwendetes Werkzeug:
      • Unscrew the 2 Phillips head screws (2x2.5 mm) around the edge of the speaker with a #00 Phillips screwdriver.
      • Use a pair of tweezers to remove the black tape on the speaker. Put the tape on the back of the new speaker.
      Frag FixBot
    4. Sony M-430 Microcassette-Corder Speaker Replacement: Schritt 10, Bild 1 von 1
      • Now that the speaker is detached from the device, simply tilt the device over and let the speaker fall out.
      Frag FixBot
Abschluss
Cal Poly, Team 10-34, Amido Winter 2012 Mitglied von Cal Poly, Team 10-34, Amido Winter 2012
CPSU-AMIDO-W12S10G34
4 Mitglieder
21 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 33
Insgesamt: 1,427
