Zum Hauptinhalt wechseln
Sony MDR-XB450AP Extra Bass Headphones Cushion Replacement
Was du brauchst
  1. Sony MDR-XB450AP Extra Bass Headphones Cushion Replacement, Cushion: Schritt 1, Bild 1 von 1
    • Begin by laying the headphones down flat on a surface.
    • Make sure that the headphone speakers are facing upward.
    • Be sure to check that the headphones are not plugged into any devices.
  2. Sony MDR-XB450AP Extra Bass Headphones Cushion Replacement: Schritt 2, Bild 1 von 1
    • Using the plastic opening tools, gently pry the speaker from the headphone's base.
    • There will be some tearing involved, but this is necessary to remove the original cushion.
    • The cushion is bonded to the headphones with a circular adhesive strip. If you plan on reusing the cushion, try to keep the adhesive attached to the cushion during removal. This way the cushion can be easily re-attached to the headphones after repair.
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 4,533
