Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
We will be teaching you the proper way to disassemble your Sony NEX-5R so that you can replace your front case. This will be helpful to those that have damaged the front case and are looking to fix it by themselves.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Open the battery pack door by moving the slider to "OPEN". Remove the 3.25 mm silver screw inside the battery pack with a Phillips screwdriver.
    • Open the battery pack door by moving the slider to "OPEN".
    • Remove the 3.25 mm silver screw inside the battery pack with a Phillips screwdriver.
  2. Remove the 3.25 mm exterior screw with a Phillips screwdriver.
    • Remove the 3.25 mm exterior screw with a Phillips screwdriver.
  3. Use the spudger to raise the corner of the case from the camera. One component of the front case should now be separate from the camera.
    • Use the spudger to raise the corner of the case from the camera.
    • One component of the front case should now be separate from the camera.
Abschluss
3 weitere Nutzer haben diese Anleitung absolviert.
Emily Trujillo
1.102 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 8-9, Regan Spring 2014 Mitglied von Cal Poly, Team 8-9, Regan Spring 2014
CPSU-REGAN-S14S8G9
4 Mitglieder
14 Anleitungen geschrieben
Can anybody tell me where I can purchase the replacement part used in this video - Regards
Chris
Chris Brookes - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 8
Insgesamt: 1,695
