Zum Hauptinhalt wechseln
Sony NEX-5R LCD Screen Replacement
Was du brauchst
    1. Sony NEX-5R LCD Screen Replacement, LCD Screen: Schritt 1, Bild 1 von 2 Sony NEX-5R LCD Screen Replacement, LCD Screen: Schritt 1, Bild 2 von 2
      • Rotate screen to upper vertical position.
      • Remove the 8 (1.0 mm) black screws from the screen backing with Phillips screwdriver.
      • Make sure to keep track of these 8 screws. They are very small and easy to get lost.
      Frag FixBot
      Kommentar hinzufügen
    2. Sony NEX-5R LCD Screen Replacement: Schritt 2, Bild 1 von 1
      In diesem Schritt verwendetes Werkzeug:
      • Remove black plate with tweezers. (Be careful not to lose the small square magnet sticking to the underside. It allows the auto rotation of the screen for selfies.)
      Frag FixBot
    3. Sony NEX-5R LCD Screen Replacement: Schritt 3, Bild 1 von 1
      • Remove the second black metal plate covering with tweezers.
      • Be careful with this plate, its shape makes it delicate.
      Frag FixBot
    4. Sony NEX-5R LCD Screen Replacement: Schritt 4, Bild 1 von 3 Sony NEX-5R LCD Screen Replacement: Schritt 4, Bild 2 von 3 Sony NEX-5R LCD Screen Replacement: Schritt 4, Bild 3 von 3
      • After removing both plates, remove the 2 (1.75 mm) Phillips screws on the bottom of the LCD screen.
      • Take off the 2 metal sliding side components. This will allow for us to slide off the screen.
      Frag FixBot
    5. Sony NEX-5R LCD Screen Replacement: Schritt 5, Bild 1 von 1
      • Remove the blue square film covering the teal chip.
      Frag FixBot
    6. Sony NEX-5R LCD Screen Replacement: Schritt 6, Bild 1 von 1
      • Lift the screen away from the backing.
      Frag FixBot
    7. Sony NEX-5R LCD Screen Replacement: Schritt 7, Bild 1 von 2 Sony NEX-5R LCD Screen Replacement: Schritt 7, Bild 2 von 2
      • Peel away the large rectangular black sheet with the tweezers.
      • Rotate the sheet so it is to the opposite side of the screen.
      Frag FixBot
    8. Sony NEX-5R LCD Screen Replacement: Schritt 8, Bild 1 von 1
      • Using the tweezers, gently pull the small orange tab away from the backing.
      • The orange taping is very fragile, so make sure not to tear it with the tweezers or rip it out of its socket.
      Frag FixBot
    9. Sony NEX-5R LCD Screen Replacement: Schritt 9, Bild 1 von 3 Sony NEX-5R LCD Screen Replacement: Schritt 9, Bild 2 von 3 Sony NEX-5R LCD Screen Replacement: Schritt 9, Bild 3 von 3
      • Use a spudger or plastic opening tool to flip the black locking tab up. Slide the cable straight out of its socket and remove the display.
      Frag FixBot
    10. Sony NEX-5R LCD Screen Replacement: Schritt 10, Bild 1 von 1
      • Some replacement LCD screens do not come with the plastic frame. The original frame is easily separated and reused. Push the LDC out of the frame from behind. This takes some force. Be careful not to break the frame.
      • After separation, removed the sticky material between them and replaced it with double sided tape.
      • On reassembly stick strips of the tape to the inside edges of the plastic frame and then trimmed them to fit with a Exacto knife.
      • The small flexible cable must be folded around the inside edge of the plastic frame and then folded again to meet the connector. Follow the folds of the original cable.
      Frag FixBot
Abschluss
12 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 8-9, Regan Spring 2014 Mitglied von Cal Poly, Team 8-9, Regan Spring 2014
CPSU-REGAN-S14S8G9
4 Mitglieder
84 Anleitungen geschrieben
14 Kommentare zur Anleitung
Success! This guide was very helpful. Here is a bit more info:
The LCD screen I ordered did not have the plastic frame. The original frame is easily separated. Push the LDC out of the frame from behind. This takes some force. Be careful not to break the frame. After separation, I removed the sticky material between them and replaced it with double sided tape. I first stuck strips of the tape to the inside edges of the plastic frame and then trimmed them to fit with a Exacto knife. The small flexible cable must be folded around the inside edge of the plastic frame and then folded again to meet the connector. Follow the folds of the original cable.
On reassembly I used a very tiny bit of double sided tape on each of the side rails, near the screw holes to hold them in place while putting on the outer most screen backing shown in step 6. When replacing this part pay special attention to the two small tabs at the bottom which must slide into slots at the bottom of the screen assembly.
Joseph Coffland - Antwort Teilen
Where can I buy the screen other than bidding on ebay
oscarpatriciorojas - Antwort Teilen
I purchased my NEX-5 replacement screen from e-Bay 'buy it now' from seller: szdigital2013. It came from China and cost a mere £10.29 inc.post.
Michael Sept.2017
michaelgamble61 - Antwort Teilen
I see it amazon but is too damned expensive 60 ,79
double sided tape did not work for me. The screen keeps popping out - what kind of glue would you suggest?
Ben - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 25
Letzte 30 Tage: 94
Insgesamt: 21,285
