Zum Hauptinhalt wechseln
Sony NEX-5R Main Navigation Button Replacement
Was du brauchst
    1. Sony NEX-5R Main Navigation Button Replacement, Rear Case: Schritt 1, Bild 1 von 1
      • Remove the three (3.5 mm) screws from the bottom of the camera with the Phillips screwdriver.
      Frag FixBot
      Kommentar hinzufügen
    2. Sony NEX-5R Main Navigation Button Replacement: Schritt 2, Bild 1 von 1
      • Open the HDMI port, and remove the the two (3.5 mm) Phillips screws exposed on that side.
      Frag FixBot
    3. Sony NEX-5R Main Navigation Button Replacement: Schritt 3, Bild 1 von 1
      • Remove the two 4mm screws from the interior of the battery pack, and one 3.5mm screw from beside it.
      Frag FixBot
    4. Sony NEX-5R Main Navigation Button Replacement: Schritt 4, Bild 1 von 1
      • Looking at the bottom of the camera, use the spudger to lift the rear case away from the camera body.
      Frag FixBot
    5. Sony NEX-5R Main Navigation Button Replacement: Schritt 5, Bild 1 von 2 Sony NEX-5R Main Navigation Button Replacement: Schritt 5, Bild 2 von 2
      • Using the spudger again, carefully pry from the top of the camera to remove the back frame.
      • The back frame is fragile, so use the spudger gently.
      Frag FixBot
    6. Sony NEX-5R Main Navigation Button Replacement: Schritt 6, Bild 1 von 1
      • The back case should now be removed and look like this.
      Frag FixBot
    1. Sony NEX-5R Main Navigation Button Replacement, Main Navigation Button: Schritt 7, Bild 1 von 1
      • Use spudger to pull the lead out from its housing.
      Frag FixBot
    2. Sony NEX-5R Main Navigation Button Replacement: Schritt 8, Bild 1 von 2 Sony NEX-5R Main Navigation Button Replacement: Schritt 8, Bild 2 von 2
      In diesem Schritt verwendetes Werkzeug:
      • Squeeze the lead with the tweezers and hold the lead teeth tightly with your fingers. Pull straight out to disconnect.
      Frag FixBot
    3. Sony NEX-5R Main Navigation Button Replacement: Schritt 9, Bild 1 von 2 Sony NEX-5R Main Navigation Button Replacement: Schritt 9, Bild 2 von 2
      • The navigation button component should now be separate and able to be replaced with new component. The camera and navigation button should appear as shown.
      Frag FixBot
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 8-9, Regan Spring 2014 Mitglied von Cal Poly, Team 8-9, Regan Spring 2014
CPSU-REGAN-S14S8G9
4 Mitglieder
84 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 31
Letzte 30 Tage: 131
Insgesamt: 5,225
