Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
The removal of the top panel involves the removal of the front case to be able to reach the screws necessary for the removal of the top panel.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Open the battery pack door by moving the slider to "OPEN". Remove the 3.25 mm silver screw inside the battery pack with a Phillips screwdriver.
    • Open the battery pack door by moving the slider to "OPEN".
    • Remove the 3.25 mm silver screw inside the battery pack with a Phillips screwdriver.
  2. Remove the 3.25 mm exterior screw with a Phillips screwdriver.
    • Remove the 3.25 mm exterior screw with a Phillips screwdriver.
  3. Use the spudger to raise the corner of the case from the camera. One component of the front case should now be separate from the camera.
    • Use the spudger to raise the corner of the case from the camera.
    • One component of the front case should now be separate from the camera.
  4. Remove the three (3.5 mm) screws from the bottom of the camera with the Phillips screwdriver.
    • Remove the three (3.5 mm) screws from the bottom of the camera with the Phillips screwdriver.
  5. Open the HDMI port, and remove the the two (3.5 mm) Phillips screws exposed on that side.
    • Open the HDMI port, and remove the the two (3.5 mm) Phillips screws exposed on that side.
  6. Remove the two 4mm screws from the interior of the battery pack, and one 3.5mm screw from beside it.
    • Remove the two 4mm screws from the interior of the battery pack, and one 3.5mm screw from beside it.
  7. Looking at the bottom of the camera, use the spudger to lift the rear case away from the camera body.
    • Looking at the bottom of the camera, use the spudger to lift the rear case away from the camera body.
  8. Using the spudger again, carefully pry from the top of the camera to remove the back frame. The back frame is fragile, so use the spudger gently.
    • Using the spudger again, carefully pry from the top of the camera to remove the back frame.
    • The back frame is fragile, so use the spudger gently.
  9. The back case should now be removed and look like this.
    • The back case should now be removed and look like this.
  10. Remove the 3.5mm phillips head screw underneath the flash port
    • Remove the 3.5mm phillips head screw underneath the flash port
  11. Remove the 3.5mm phillips head screw on the top left of the camera.
    • Remove the 3.5mm phillips head screw on the top left of the camera.
  12. Use the spudger tool to go around the seam  of the top panel. The top should easily lift off.
    • Use the spudger tool to go around the seam of the top panel. The top should easily lift off.
  13. This is what the camera and top panel should look like after you have completed the guide This is what the camera and top panel should look like after you have completed the guide
    • This is what the camera and top panel should look like after you have completed the guide
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Steven Fronczak
309 Reputation
1 Anleitung geschrieben
Cal Poly, Team 8-9, Regan Spring 2014 Mitglied von Cal Poly, Team 8-9, Regan Spring 2014
CPSU-REGAN-S14S8G9
4 Mitglieder
14 Anleitungen geschrieben
Hey Steven! This is all wrong! That's not the wright order: actually the top panel is the first part that can be removed, you don't need to tear down the rear panel and the front handgrip.. (it also may cause the damage of the rear panel!).
So, in order to remove the top panel just follow this order:
STEP 2
STEP 5 (Just the upper screw (not that one between HDMI and USB port)
STEP 6 (Just the two 4mm screws)
STEP 10
STEP 12
Its a lot easier ;)
Daniele
Daniele Fior - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 8
Insgesamt: 2,022
