Zum Hauptinhalt wechseln
Sony NEX-7 Battery Replacement
  1. Sony NEX-7 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Sony NEX-7 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • We need to turn off the camera because we are removing components that could get damaged if the power is still on.
    • If the camera is on, rotate the power switch on top of the camera counterclockwise to turn the camera off.
  2. Sony NEX-7 Battery Replacement: Schritt 2, Bild 1 von 1
    • Flip the camera over such that the power switch points down.
    • Slide the switch on the bottom of the camera grip towards the lens to open the battery door.
  3. Sony NEX-7 Battery Replacement: Schritt 3, Bild 1 von 1
    • With the battery door open, push the blue lever in the battery compartment to release the battery.
Abschluss
To replace the battery, fit it in the slot, then close and lock the door.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Tyler
569 Reputation
1 Anleitung geschrieben
Cal Poly, Team 10-55, Amido Spring 2014 Mitglied von Cal Poly, Team 10-55, Amido Spring 2014
CPSU-AMIDO-S14S10G55
4 Mitglieder
31 Anleitungen geschrieben
Ein Kommentar
I’ve done this about a million times. :)
Martin Hurley - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 14
Insgesamt: 2,036
