Zum Hauptinhalt wechseln
Sony NWZ-E473 Screen Replacement
Was du brauchst
  1. Sony NWZ-E473  Screen Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Use a Phillips #00 screwdriver to unscrew the two 5 mm screws located on the bottom of the back of the device.
  2. Sony NWZ-E473  Screen Replacement: Schritt 2, Bild 1 von 1
    • Use a plastic opening tool to loosen the bottom portion of device.
  3. Sony NWZ-E473  Screen Replacement: Schritt 3, Bild 1 von 1
    • Use a plastic opening tool to loosen the top panel of the device.
  4. Sony NWZ-E473  Screen Replacement: Schritt 4, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws located on the portion under the top panel of the device.
  5. Sony NWZ-E473  Screen Replacement: Schritt 5, Bild 1 von 3 Sony NWZ-E473  Screen Replacement: Schritt 5, Bild 2 von 3 Sony NWZ-E473  Screen Replacement: Schritt 5, Bild 3 von 3
    • Remove the back plate from the device.
  6. Sony NWZ-E473  Screen Replacement, Screen: Schritt 6, Bild 1 von 1
    • Use a nylon spudger or tweezers to remove the plastic USB cover.
  7. Sony NWZ-E473  Screen Replacement: Schritt 7, Bild 1 von 1
    • Use a Phillips #00 screwdriver to unscrew two 2 mm screws located on the top corners of the device.
  8. Sony NWZ-E473  Screen Replacement: Schritt 8, Bild 1 von 1
    • Use a nylon spudger or tweezers to remove the plastic protective plate at the top of device.
  9. Sony NWZ-E473  Screen Replacement: Schritt 9, Bild 1 von 2 Sony NWZ-E473  Screen Replacement: Schritt 9, Bild 2 von 2
    • Remove the plastic protective frame located over the motherboard with tweezers and a spudger.
  10. Sony NWZ-E473  Screen Replacement: Schritt 10, Bild 1 von 1
    • Remove screen connection from motherboard using tweezers and spudger.
  11. Sony NWZ-E473  Screen Replacement: Schritt 11, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove two 3 mm screws at the bottom sides and two 1 mm screws at top sides of the device.
  12. Sony NWZ-E473  Screen Replacement: Schritt 12, Bild 1 von 2 Sony NWZ-E473  Screen Replacement: Schritt 12, Bild 2 von 2
    • Use a Phillips #00 screwdriver to unscrew two 2 mm screws, and remove the motherboard from the device with tweezers and a plastic opening tool.
  13. Sony NWZ-E473  Screen Replacement: Schritt 13, Bild 1 von 2 Sony NWZ-E473  Screen Replacement: Schritt 13, Bild 2 von 2
    • Disconnect the metal shielding plate from the front panel with tweezers or a plastic opening tool.
  14. Sony NWZ-E473  Screen Replacement: Schritt 14, Bild 1 von 2 Sony NWZ-E473  Screen Replacement: Schritt 14, Bild 2 von 2
    • Use a plastic opening tool to remove the screen from metal back plate.
Abschluss
Matthew Hintz
327 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 17-6, Watkins Winter 2015 Mitglied von USF Tampa, Team 17-6, Watkins Winter 2015
USFT-WATKINS-W15S17G6
4 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
very helpful!!! thx
Stefan Taubert - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 918
