Einleitung
To complete this Sony NWZ-E473 guide, a soldering iron will be needed. You may want to have someone with soldering iron experience complete that step or watch some basic videos on how to use a soldering iron.
Was du brauchst
Use a Phillips #00 screwdriver to unscrew the two 5 mm screws located on the bottom of the back of the device.
Use a Phillips #00 screwdriver to remove the two 3 mm screws located on the portion under the top panel of the device.
Peel back the layer of tape along with the processor, which is located just below the battery, using the tweezers and the spudger.
Slide a prying tool underneath the top portion of the battery and lift it from the case.
Remove the stickers from the battery terminals, which are on the underside of the battery.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Hi their I have a Sony nwz-e355 walkman I want to replace the battery in it cause I thinks it's done I see u do a replacement for the e473 wondering if u have e355 batteries or will this e473 battery work in my walkman both need to be soildered in any feed back would help
I have the same model. I have 2 of them purchased years ago from Ubid.com. A very cool device. SONY ought to service them when the batteries fade…
