Einleitung
This repair might be needed if your 3D glasses will not connect to your Sony PlayStation 3D Display.
Was du brauchst
With the Phillips #02 screwdriver, remove the six 6 mm length x 6 mm head screws from the back plate.
With the Phillips #02 screwdriver, remove the ten 6 mm length x 8 mm head screws from the back plate.
Remove back plate with a plastic opening tool by slowing prying around the entire plate.
Once separated the plate easily lifts off.
With the Phillips #01 screwdriver, remove the two 5 mm length x 7 mm head screws that hold the 3D Sync Transmitter in place.
Pry the tab slightly up with your thumbnail and pull the connector away from the board.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
