Einleitung
This repair may be needed if your device functions properly, but the indicator lights do not work.
Was du brauchst
With the Phillips #02 screwdriver, remove the six 6 mm length x 6 mm head screws from the back plate.
With the Phillips #02 screwdriver, remove the ten 6 mm length x 8 mm head screws from the back plate.
Remove back plate with a plastic opening tool by slowing prying around the entire plate.
Once separated the plate easily lifts off.
With the Phillips #02 screwdriver, remove the two 5mm length x 5mm head screws located on the left and right side of the light bar board.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
