Einleitung
This machine is a childhood memory, it had classical games like GTA SA, Tomb Raider and Shadow of the Colossus! Though unfortunately, your Playstation 2's front cover broke. Fortunately this guide will show you how to replace your broken front cover!
Was du brauchst
You'll see some outlined grey tabs on the outline of the back, get a spudger or something flat to pop them off.
When you take off all the tabs, there should be a Phillip Head screw under each tab, unscrew them.
Once you have unscrew them, gently take off the front cover of the Playstation 2.
Get your replacement front cover and prepare to put it back on.
Align the front cover and put the front cover firstly on the selected area.
Put the screws in their correct place and screw them into the Playstation 2.
When done screwing, put the tabs into their correct places.
You have now put a new front cover onto your Playstation 2 superslim!
Eine weitere Person hat diese Anleitung absolviert.
