Zum Hauptinhalt wechseln
Sony Pulse Elite Edition Battery Replacement
Was du brauchst
  1. Sony Pulse Elite Edition Battery Replacement, Identifying Earpiece: Schritt 1, Bild 1 von 1
    • Locate the left side designation on the headband-earpiece junction.
    • The battery is in the right earpiece.
    • The motherboard is in the left earpiece.
  2. Sony Pulse Elite Edition Battery Replacement, Ear Cushion Removal: Schritt 2, Bild 1 von 2 Sony Pulse Elite Edition Battery Replacement, Ear Cushion Removal: Schritt 2, Bild 2 von 2
    • Gently pull around the perimeter of the left ear cushion until it comes off.
  3. Sony Pulse Elite Edition Battery Replacement, Outer Ear Rim Removal: Schritt 3, Bild 1 von 2 Sony Pulse Elite Edition Battery Replacement, Outer Ear Rim Removal: Schritt 3, Bild 2 von 2
    • Use the PH00 Screwdriver to remove the three Phillips 6mm screws around the perimeter of the ear cup.
    • Gently pull the outer ear rim off of the headset assembly.
    • Harsh removal may cause permanent damage to the speaker wires.
  4. Sony Pulse Elite Edition Battery Replacement, Remove Speaker Housing: Schritt 4, Bild 1 von 1
    • Using tweezers, gently pry the red and black speaker wires from the attached socket.
  5. Sony Pulse Elite Edition Battery Replacement, Remove Battery: Schritt 5, Bild 1 von 2 Sony Pulse Elite Edition Battery Replacement, Remove Battery: Schritt 5, Bild 2 von 2
    • Lift up battery and disconnect wires using tweezers.
    • Use a new battery for reconstruction.
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
Chris Echter
865 Reputation
4 Anleitungen geschrieben
Clemson, Team 14-2, Shirley Spring 2015 Mitglied von Clemson, Team 14-2, Shirley Spring 2015
CLEM-SHIRLEY-S15S14G2
5 Mitglieder
12 Anleitungen geschrieben
7 Kommentare
Where can I buy the replacement battery for this?
Pretty hard to find...
francisklalumiere - Antwort
Replacement batteries can be found by googling "SP70C battery". It is a Lithium battery with 900mAh and a 3.7v output. AliExpress shows them for $11 including shipping.
David McAndrews - Antwort
Can I mod and replace the battery with a bigger one with no white connection, just positive and negative? Thanks!
marit - Antwort
Thank you so much for this guide. I got a 1000mAh batter from Amazon for 10 dollars. It lasts way longer and was extremely easy to install. Very thankful for this. Thanks!
sharku19z - Antwort
i just attempted... the connector to the battery just pulled off. NOTE: Pull up from PCB not out. The connector sets down into it.
Garrett Parmenter - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 54
Insgesamt: 10,531
