Zum Hauptinhalt wechseln
Sony RDR HX750 HX950 Disassembly
Was du brauchst
  1. Sony RDR HX750 HX950 Disassembly, Remove cover: Schritt 1, Bild 1 von 3 Sony RDR HX750 HX950 Disassembly, Remove cover: Schritt 1, Bild 2 von 3 Sony RDR HX750 HX950 Disassembly, Remove cover: Schritt 1, Bild 3 von 3
    • Remove the screws from the back and sides of the top cover.
  2. Sony RDR HX750 HX950 Disassembly, Remove Hard Disk: Schritt 2, Bild 1 von 3 Sony RDR HX750 HX950 Disassembly, Remove Hard Disk: Schritt 2, Bild 2 von 3 Sony RDR HX750 HX950 Disassembly, Remove Hard Disk: Schritt 2, Bild 3 von 3
    • Remove the four screws that secure the hard drive mounting bracket to the bottom of the unit.
    • Unplug the two cables from the rear of the hard drive.
    • Remove the four screws from the bottom of the hard drive mounting bracket.
  3. Sony RDR HX750 HX950 Disassembly, Remove DVD player: Schritt 3, Bild 1 von 3 Sony RDR HX750 HX950 Disassembly, Remove DVD player: Schritt 3, Bild 2 von 3 Sony RDR HX750 HX950 Disassembly, Remove DVD player: Schritt 3, Bild 3 von 3
    • Remove the screws from the DVD cover
    • Remove the screws from the plastic cable holder
  4. Sony RDR HX750 HX950 Disassembly, Remove front Panel: Schritt 4, Bild 1 von 3 Sony RDR HX750 HX950 Disassembly, Remove front Panel: Schritt 4, Bild 2 von 3 Sony RDR HX750 HX950 Disassembly, Remove front Panel: Schritt 4, Bild 3 von 3
    • Insert the paper under each "click" to remove the front panel.
    • Once each "click" is loose, push the front panel gently.
    • The table of the compact disk has a little plastic piece in front that goes up to come out with a "click"
  5. Sony RDR HX750 HX950 Disassembly, Remove  DVD block: Schritt 5, Bild 1 von 3 Sony RDR HX750 HX950 Disassembly, Remove  DVD block: Schritt 5, Bild 2 von 3 Sony RDR HX750 HX950 Disassembly, Remove  DVD block: Schritt 5, Bild 3 von 3
    • Unplug the cables show in photo.
    • Disconnect the cable hidden on the side.
    • Remove the piece on the cd reader
  6. Sony RDR HX750 HX950 Disassembly, Remove cover of dvd player: Schritt 6, Bild 1 von 3 Sony RDR HX750 HX950 Disassembly, Remove cover of dvd player: Schritt 6, Bild 2 von 3 Sony RDR HX750 HX950 Disassembly, Remove cover of dvd player: Schritt 6, Bild 3 von 3
    • Under the DVD block, remove the screws as shown.
    • Remove the screws on the board.
    • Now the laser can be accessed.
  7. Sony RDR HX750 HX950 Disassembly, Sony RDR HX750 laser: Schritt 7, Bild 1 von 3 Sony RDR HX750 HX950 Disassembly, Sony RDR HX750 laser: Schritt 7, Bild 2 von 3 Sony RDR HX750 HX950 Disassembly, Sony RDR HX750 laser: Schritt 7, Bild 3 von 3
    • Inserir instruções aqui.
Abschluss
To open this dvd recorder folow this tutorial
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cafony
687 Reputation
4 Anleitungen geschrieben
Ein Kommentar
Hello,HX950 work only with hdd 250Gb,or another,with 500 or 1000Gb ???
Cornelus - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 48
Insgesamt: 5,373
