Zum Hauptinhalt wechseln
Sony RMT-D197A Battery Contactor Repair
Was du brauchst
  1. Sony RMT-D197A Battery Contactor Repair, Sony RMT-D197A Battery Contactor Repair: Schritt 1, Bild 1 von 2 Sony RMT-D197A Battery Contactor Repair, Sony RMT-D197A Battery Contactor Repair: Schritt 1, Bild 2 von 2
    • Place the remote on a solid, sturdy surface.
    • Use a putty knife to gently pry open the remote.
  2. Sony RMT-D197A Battery Contactor Repair: Schritt 2, Bild 1 von 2 Sony RMT-D197A Battery Contactor Repair: Schritt 2, Bild 2 von 2
    • Remove the front panel from the remote.
  3. Sony RMT-D197A Battery Contactor Repair: Schritt 3, Bild 1 von 1
    • Wear safety glasses and use caution when handling a hot soldering iron.
    • Use the soldering iron to gently desolder the damaged battery contactor.
    • Keep in mind the battery contactor can easily break so make sure to be gentle with the soldering iron.
  4. Sony RMT-D197A Battery Contactor Repair: Schritt 4, Bild 1 von 2 Sony RMT-D197A Battery Contactor Repair: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use a pair of tweezers to remove the spring from the contactor.
  5. Sony RMT-D197A Battery Contactor Repair: Schritt 5, Bild 1 von 1
    • Use the soldering iron to melt solder onto the empty hole.
    • Make sure to accurately place the spring into the correct position.
  6. Sony RMT-D197A Battery Contactor Repair: Schritt 6, Bild 1 von 2 Sony RMT-D197A Battery Contactor Repair: Schritt 6, Bild 2 von 2
    • Reattach the two halves of the remote.
  7. Sony RMT-D197A Battery Contactor Repair: Schritt 7, Bild 1 von 1
    • Insert batteries and try out your remote.
Ziellinie
3 weitere Nutzer:innen haben diese Anleitung absolviert.
York University, Team 2-10, O'Regan Fall 2021 Mitglied von York University, Team 2-10, O'Regan Fall 2021
YORK-O'REGAN-F21S2G10
1 Mitglied
2 Anleitungen geschrieben
Ein Kommentar
As the remote is already disassembled, I took the opportunity to clean the contacts for all the buttons using alcohol.
Jason Lee - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 20
Insgesamt: 417
