Zum Hauptinhalt wechseln
Sony Radio CD player and cassette player CFD-S05 Circuit Board Replacement
Was du brauchst
  1. Sony Radio CD player and cassette player CFD-S05 Circuit Board Replacement, Sony Radio Model CFD S05 Prerequisite steps Replacement: Schritt 1, Bild 1 von 1
    • Unscrew the screws on the top of the radio.
  2. Sony Radio CD player and cassette player CFD-S05 Circuit Board Replacement: Schritt 2, Bild 1 von 2 Sony Radio CD player and cassette player CFD-S05 Circuit Board Replacement: Schritt 2, Bild 2 von 2
    • Open the CD and cassette doors and remove the screws in the compartments.
    • To open the CD door push on the bottom left corner of the CD door. To open the cassette door push the button that is to the left of the pause button.
  3. Sony Radio CD player and cassette player CFD-S05 Circuit Board Replacement: Schritt 3, Bild 1 von 1
    • Flip the radio upside down and remove the battery cover. Unscrew the one screw below the batteries.
  4. Sony Radio CD player and cassette player CFD-S05 Circuit Board Replacement: Schritt 4, Bild 1 von 1
    • Remove the top of the radio enough to access the wires for removal.
    • Do not forcefully remove the whole top piece of the radio! There will be wires connected to the top cover and circuit board.
  5. Sony Radio CD player and cassette player CFD-S05 Circuit Board Replacement: Schritt 5, Bild 1 von 1
    • Remove all of the wires that are connected to both the circuit board and the underside of the top of the radio by pulling them where they are connected
    • This should include three sets of red and white wires, one set of white wires, one set of black wires, and two ribbon wires. Some cannot be disconnected from the top piece of the radio. Disconnect these plugs from the circuit board.
  6. Sony Radio CD player and cassette player CFD-S05 Circuit Board Replacement, Circuit Board: Schritt 6, Bild 1 von 1
    • Unscrew the screws in the circuit board.
  7. Sony Radio CD player and cassette player CFD-S05 Circuit Board Replacement: Schritt 7, Bild 1 von 1
    • Unlodge the green headphone jack on the back of the circuit board by pulling on the back of the radio and lifting the circuit board up.
    • This may be a little difficult and don't pull to hard because the radio may crack.
  8. Sony Radio CD player and cassette player CFD-S05 Circuit Board Replacement: Schritt 8, Bild 1 von 1
    • Lift the circuit board out of the radio.
  9. Sony Radio CD player and cassette player CFD-S05 Circuit Board Replacement: Schritt 9, Bild 1 von 1
    • Insert and align the new circuit board and screw it down.
  10. Sony Radio CD player and cassette player CFD-S05 Circuit Board Replacement: Schritt 10, Bild 1 von 1
    • Reconnect the wires that were unplugged from the prerequisite steps.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
Ian Nussman
959 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2013 Mitglied von UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S2G5
2 Mitglieder
1 Kommentar zur Anleitung
Where can I get the part?
Francois - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 47
Insgesamt: 6,346
