Zum Hauptinhalt wechseln
Sony Radio CD player and cassette player CFD-S05 Optical Pickup Unit Replacement
Was du brauchst
  1. Sony Radio CD player and cassette player CFD-S05 Optical Pickup Unit Replacement, Sony Radio Model CFD S05 Prerequisite steps Replacement: Schritt 1, Bild 1 von 1
    • Unscrew the screws on the top of the radio.
  2. Sony Radio CD player and cassette player CFD-S05 Optical Pickup Unit Replacement: Schritt 2, Bild 1 von 2 Sony Radio CD player and cassette player CFD-S05 Optical Pickup Unit Replacement: Schritt 2, Bild 2 von 2
    • Open the CD and cassette doors and remove the screws in the compartments.
    • To open the CD door push on the bottom left corner of the CD door. To open the cassette door push the button that is to the left of the pause button.
  3. Sony Radio CD player and cassette player CFD-S05 Optical Pickup Unit Replacement: Schritt 3, Bild 1 von 1
    • Flip the radio upside down and remove the battery cover. Unscrew the one screw below the batteries.
  4. Sony Radio CD player and cassette player CFD-S05 Optical Pickup Unit Replacement: Schritt 4, Bild 1 von 1
    • Remove the top of the radio enough to access the wires for removal.
    • Do not forcefully remove the whole top piece of the radio! There will be wires connected to the top cover and circuit board.
  5. Sony Radio CD player and cassette player CFD-S05 Optical Pickup Unit Replacement: Schritt 5, Bild 1 von 1
    • Remove all of the wires that are connected to both the circuit board and the underside of the top of the radio by pulling them where they are connected
    • This should include three sets of red and white wires, one set of white wires, one set of black wires, and two ribbon wires. Some cannot be disconnected from the top piece of the radio. Disconnect these plugs from the circuit board.
  6. Sony Radio CD player and cassette player CFD-S05 Optical Pickup Unit Replacement, Optical Pickup Unit: Schritt 6, Bild 1 von 1
    • Unscrew the three screws on the optical pick up unit, which is on the underside of the cover
    • The optical pick up unit is located directly beneath the CD player on the underside of the top face of the radio.
  7. Sony Radio CD player and cassette player CFD-S05 Optical Pickup Unit Replacement: Schritt 7, Bild 1 von 1
    • Insert the new optical pick up unit.
    • Make sure it is aligned properly.
  8. Sony Radio CD player and cassette player CFD-S05 Optical Pickup Unit Replacement: Schritt 8, Bild 1 von 1
    • Screw in the new optical pick up unit.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Ian Nussman
959 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2013 Mitglied von UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S2G5
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 42
Insgesamt: 3,231
