Einleitung
If the radio reception on your Sony Radio Model CFD S05 is poor even with repeated reorientation of the antenna and repositioning of the unit, then the problems may lie with a damaged or unresponsive antenna. Before using this guide, you should inspect the antenna and connecting port on your radio for any bending or loose screws, making sure that the antenna is the main reason for the faulty radio system. This guide will help you understand how to replace the antenna which could result in the radio receiving signals and better sound quality.
Was du brauchst
Locate the screw on the back of the radio, in the right hand corner Remove the screw holding the antenna in place.
Insert the new antenna into place. Replace the screw, and attach the antenna to the radio.
2 weitere Personen haben diese Anleitung absolviert.
